OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Razer ManO'War Wireless PC Gaming Headset @ £154.99 inc VAT
Available to pre-order on our website now. Release date for UK not officially confirmed yet but should be around mid-May. Let us know your thoughts below....
LAG-FREE WIRELESS PERFORMANCE AUDIO
The Razer ManO’War offers high fidelity gaming grade audio through lag-free 2.4 GHz wireless technology with a 12+2 meter range capability. Simply plug-and-play with the ultra-compact wireless USB adapter or use the included extension dock for the extended range of 14 meters.
WIRELESS 7.1 VIRTUAL SURROUND SOUND FOR PINPOINT PRECISION
Enhanced with the powerful Razer Surround engine, the immersive 7.1 channel virtual surround sound paired with the Razer ManO’War’s high-performance 50 mm Neodymium magnet drivers makes the battlefield around you come alive. Fully utilize the positional audio calibration feature to accurately pinpoint your enemies so you can get the jump on them before they do.
7 DAYS OF WIRELESS GAMING ON A SINGLE CHARGE*
Whether you’re streaming, watching a movie or on a gaming marathon, the Razer ManO’War is able to give you an impressive 7 days of wireless gameplay [14 hours uninterrupted play on a single charge]. Never worry about having mediocre battery life ever again so you can focus fully on your missions.
RETRACTABLE DIGITAL MIC FOR UNCOMPROMISED VOCAL CLARITY
Concealed in the left ear cup is a versatile unidirectional digital microphone boom which easily pulls out as needed, and adjusts to the exact position you want. Equipped with an optimized algorithm for more natural sounding and crystal clear voice reproduction, the Razer ManO’War’s digital microphone surpasses the capabilities of traditional analog microphones. The headset also comes with a mute LED indicator on the microphone boom so you always know when you’re broadcasting.
QUICK ACTION CONTROLS ON THE EAR CUPS FOR ON-THE-FLY AUDIO ADJUSTMENTS
Armed with intuitive Quick Action Controls on the Razer ManO’War’s ear cups, you will call the shots with ease. Adjust mic and volume levels and mute without ever fumbling with onscreen controls so you can stay focused on your target.
Specifications:
Headphones:
Frequency response: 20 – 20 kHz
Impedance: 32 ? ¬ at 1 kHz
Sensitivity (@1 kHz): 112 ± 3 dB
Input power: 30 mW (Max)
Drivers: 50 mm, with Neodymium magnets
Inner ear cup diameter: 60 mm / 2.36 in
Connection type: Wireless USB Transceiver
Wireless range: 12 m / 40 ft
Wireless frequency: 2.4 Ghz
Battery life: Up to 14 hours with Razer Chroma lighting / 20 hours without Razer Chroma lighting
Approximate weight: 375 g / 0.83 lbs
Microphone:
Frequency response: 100 – 10 kHz
Signal-to-noise ratio: > 60 dB
Sensitivity (@1 kHz): -38 ± 3 dB
Pick-up pattern: Unidirectional
SYSTEM REQUIREMENTS
PC / Mac with USB port; PlayStation ® 4*
Windows® 10 / Windows® 8 / Windows® 7 / Mac OS X (10.9 and higher)
Internet connection for driver installation
At least 100 MB of free hard disk space
* Only Spectrum cycling lighting effect and 2.0 stereo audio output is available
Only £154.99 inc VAT.
ORDER NOW
View our entire headset range here
Specifications:
Headphones:
Microphone:
SYSTEM REQUIREMENTS
ORDER NOW
