Razer Naga 2009 replacement
10 Jan 2012
Sunderland, UK
Hey, I've had my Naga since well...2009 repaired it many times but its about kicked the bucket, the left click is mushy and theres nothing I can do to fix it.
There are not really any replacements for the 2009 as its an old mouse.
The newer versions are too BIG and WIDE. I like the sleek 2009 version of the naga. Anyone know of a similar size mouse? the buttons don't particularly matter.
been in the same situation as you, me and my wife been playing wow for over a decade
the old naga is the best there is!
same as you, we had to replace ours
we own the new naga and the wireless naga and the corsair mmo mouse
the corsair is not good, the side buttons are not num buttons, they are all program buttons so you have to program each button individually, the side buttons also cave in the way, so they are not well spaced out, also thumb travel between top to bottom button is quite far.
the old naga the side buttons cave out the way so the buttons are well spaced out
the new naga the buttons are more flat and the mouse is bigger
the best replacement would be the newer naga, its not as good but it is the closest
the wireless version is slightly heavier so best is the wired version!
