Hi Guys
Over the bank holiday weekend, All Razer Naga Chroma mice will ship with a free Razer Goliathus Gaming Surface worth £11.99.
Razer Naga Chroma MMO RGB LED Gaming Mouse @ £69.95 inc VAT
The Razer Naga Chroma's original 12 button thumb grid is outfitted with mechanical switches to give you tactile and audible feedback, so you can be assured of every actuation.
The thumb grid's buttons have a concave shape to allow each button to stand out individually. This allows for blind-find so you stay focused on the game, letting your instincts and reflexes lead you to victory.
Boasting the world's most precise True 16,000 DPI 5G Laser gaming mouse sensor, with 0 interpolation, the Razer Naga Chroma provides you with unsurpassable accuracy, so you'll have an even greater edge over your competition. With its ability to track 1 DPI increments and a lift-off cut-off distance as precise as 0.1 mm, you can react instantly while you skillfully maneuver your way to victory.
With Chroma customizable lighting for both the scroll wheel and thumb grid, you can choose from an impressive spectrum of colors to personalize your Razer Naga Chroma. As each region is controlled independently via Razer Synapse, you can make this truly unique mouse distinctly yours.
When you enable the Grid Assist Display overlay in-game, you’ll be able to refer to exactly where every skill has been set on the grid.
You can even configure your entire mouse’s setup from inside the game. Never have to Alt-Tab or exit a game to prepare yourself before an epic dungeon raid or boss fight. Set the transparency to make the overlay more prominent or less intrusive as you need.
If you play World of Warcraft, we’ve got a special configurator developed just for it. Intuitively drag and drop your skills right onto the overlay to customize your loadout. Create as many grids so you have all necessary skills ready on-hand.
Note: In-game configurator support is compatible with Windows 10 / Windows 8 / Windows 7
Features:
- Total of 19 MMO optimized programmable buttons
- 12 button mechanical thumb grid
- True 16,000 DPI 5G Laser Sensor, with 0 interpolation
- Chroma lighting with 16.8 million customizable color options
- Tilt click scroll wheel
- Up to 210 inches per second / 50 G acceleration
- 1000 Hz Ultrapolling / 1 ms response time
- Inter-device color synchronization
- Razer Synapse enabled
- Zero-acoustic Ultraslick mouse feet
- 2.1 m / 7 ft braided fiber USB cable
- Approximate size : 119 mm / 4.68 in (Length) x 75 mm / 2.95 in (Width) x 43 mm / 1.69 in (Height)
- Approximate weight: 135 g / 0.30 lbs with cable
Only £69.95 inc VAT.
ORDER NOW
COMES FREE WITH:
Razer Goliathus Small Speed Gaming Surface @ £11.99 inc VAT
Heavily textured weave for CONTROL gameplay
The micro-textures on the surface of the Razer Goliathus deliver the right amount of friction to your gaming mouse’s movements, so you get pixel-precise targeting for absolute in-game accuracy. The weave also provides a nice, comfortable feel under your hand minimizing fatigue over extended periods of play.
Optimized for All Sensitivity Settings and Sensors
Low sense, high sense, laser, optical or dual sensor system – whatever your sensitivity setting or preferred gaming mouse, the Razer Goliathus offers total tracking responsiveness for consistently reliable in-game control.
Slick, taut weave for SPEED gameplay
Pixel-precise targeting and tracking
Optimized for all mouse sensitivities and sensors
Highly portable cloth-based design
Anti-fraying stitched frame
Anti-slip rubber base
Specifications:-
- Size:Small
- Surface:Cloth Weave
- Base:Anti-slip rubber base
- Product Width:270mm
- Product Length:215mm
- Product Height:3mm
- Product Weight:110g
- Package Width:8cm
- Package Length:29cm
- Package Height:8cm
- Gross Weight:0.21Kg
Only £11.99 inc VAT.
ORDER NOW
https://www.overclockers.co.uk/brands/razerVIEW THE FULL RAZER GAMING RANGE HERE
Features:
ORDER NOW
COMES FREE WITH:
Specifications:-
- Size:Small
- Package Width:8cm
ORDER NOW
