razer naga chroma
24 Aug 2011
Hi all!
I recently bought a razer naga chroma mouse to match my sexy keyboard \o/
The problem im getting is...
When I first turn the pc on - it just hangs on the boot screen. I have to press the del button and then it will load up. Once loaded.. the mouse is not detected! When I unplug it and plug it in it works ok but does not get detected in synapse so all the buttons do not work. I then have to reboot the pc.. hang on boot screen press del and once loaded it all works ok. Until I turn the pc off and have to repeat the process.
Any ideas? I've had the boot up problem since I bought the keyboard which was 6 months ago.. not really a big problem as I can just press del and it would load. But now its causing mouse problems :S
The problem seems to get worse now, its just taken me 6 restarts to get the mouse to load up in synapse.
I've tried the razer help which is rubbish :|
Make sure that USB ports are not in hibernation mode. Please go to your Windows “Device Manager” and click the + sign next to Universal Serial Bus Controllers. Click on any “Root Hub” and select “Properties.” Click the Power Management tab and ensure that “Allow computer to turn off this device to save power” is not checked and proceed to do this under each Root Hub
Any ideas?
