Razer Wolverine V3 Pro
7 May 2013
Anyone picked one of these up? Having some weird disconnecting issues with it. Updated to latest firmware but even when using a wired connection it seems to switch itself off momentarily then back on. Any ideas?
Have you got another device or something to use it on to rule out which is at fault? If it's the same wired or wireless then it's sounding like a faulty pad to me but if it's the same PC then it could be that if USB selective suspend is doing something crazy.
