Razor Pro 1.6...cant open config
26 Jan 2006
Belfast
.Hi, got the Razor v1.6 as suggested here, so installed the drivers ect for the configuration, but it says this wont work on an Intel based mac, and I cant open the config settings.
Any suggestions?
I have the newest iMac.
Kinda sorted it with an update, but does anyone know how to get some of the same options as the MM?
I kinda liked the ability to hit both the side buttons to get all the windows on the screen and select what I wanted to wrok in.
You are referring to "Exposé" which is customisable from the standard mouse configuration pane in system preferences.
got a .7 update for them and now it works fine, been able to customise all the buttons etc etc.
