RCA plug snapped off inside soundbar - Sparky advice needed
smr
smr
6 Mar 2008
Leicestershire
Hi all,
As title, my 1 year old has had at the soundbar connected to the TV downstairs and the RCA plug has snapped off inside it - I think I've made it worse trying to ply it out and pushed it in even further - tried the heat trick but that's not working.
The bar itself has two optical inputs so I could use them instead - I'm just wondering if it's safe to still use it with the broken rca plug still inside the red rca socket - won't damage the unit will it if I use the optical sockets instead - and won't damage my TV will it?
Many thanks for any help.
Just open it up and push the pin back out, or if the back is closed get a very small HSS drill bit and try and get it to bite onto the bit of plug that remains.
