http://pci-ids.ucw.cz/read/PC/1002Originally Posted by PCI Device Registry
5a10 RD890 Northbridge only dual slot (2x16) PCI-e GFX Hydra part
5a11 RD890 Northbridge only single slot PCI-e GFX Hydra part
5a12 RD890 Northbridge only dual slot (2x8) PCI-e GFX Hydra part
http://www.lucidlogix.com/files/hydra_100_product_brief.pdf
http://www.wipo.int/pctdb/en/fetch....03756&IA=US2008006342&LANG=ENG&DISPLAY=STATUS
Looks like ATI are planing to allow mixed multi GPU Vendor independent option on the new chipset that all add to the work load dynamically so as that a weaker GPU will only get the data it can handle with out holding up the faster GPUs which may also help for distributing CPU/GPU OpenCL 1.0=CUDA like but for any vendor.
