Re assurance requested ref.Q9550
31 Oct 2007
Gods County(Allegedly)
Am running said cpu @ 3.4 (400x8.5) with 1.1875v per bios and 1.168v per cpu-z. Air cooled - Tuniq.
Stable after running Prime 95 Small tft's test for 30mins+ (It failed test after 7min with v @1.165 in bios)
Temps are Idle 34/32/32/30
Load 53/52/52/49
Core 3 always runs 3/5c cooler than other cores.(Core 0 is always 1/2c higher than the cores 1 &2)
Temps are per RealTemp. Core Temp shows +5c across the board.
Running cool enough?
Should I try to cool further?
Any worries with core 3 temp?
OR am I just being paranoid ? (Got to be good at something:D)
