Ok, posted a few days ago, with very little idea what i wanted. I now have a much better idea, since I've refreshed the knowledge a bit and have a some more cash to play with now i have a buyer for my old box....
I'm look to overclock as much as possible (~4.5-4.8GHz), so if you can recommend great cooling options, whilst keeping it quiet then please advise:
Gainward GeForce GTX 560Ti "Phantom" 1024MB GDDR5 PCI-Express Graphics Card
£199.99
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor £161.99
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G)
£99.98
Fractal Design Define XL Full Tower Case - Black Pearl
£84.98
G.Skill RipJawsX 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-8GBXM)
£79.19
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI)
£119.98
I already have a 620w Corsair HX that I won't be replacing, but I need advice on the following:
Motherboard - I won't be using a cached SSD, as it will be my OS drive. I do, however, want the following features if possible: poweroff-USB Charging, bluetooth built in, play aux-in through speakers whilst switched off.
CPU cooler - As quiet, but also as efficient as possible.
Budget is around £250 for both.
I'd also consider another case, if anyone knows of any that are equally (or more) quiet, but that already have USB3.0 ports built into the front/top.
Please offer opinions, all greatly received!
£199.99
£99.98
£84.98
£79.19
£119.98
