Hey,
Just finished (well kind of) wiping my OS hard drive and re-installing everything.
Prior to doing this I exported my iTunes library (the file - not the music) to another HD, which also happens to be where my music files actualy are.
I have re-installed iTunes, however I can't seem to import the library that I exported.
I've viewed various websites, including one that talks about holding shift down to open from start menu.... the process worked, but it was looking for a .itl file when my library file is an XML.
Oddly enough, I've been able to import my playlists from this file, but not the songs.
Have I made a major booboo or can someone please offer any advice?
Regards
Lee
Regards
Lee
which if you got a lot of mucis might take you soem time
