RE-overclocking 920D0
6 Jul 2010
Hey guys,
I've flashed my bios to newer ones and overclocking's gone, so I'm trying once more to achieve the best overclock/temp/volt. So far I'm here:
My concern is that I've lowered the voltage from 1.15 to 1.12 and still the max temps are the same, should I leave it as it is, or go on till it crashes and then just put the previous best one?
I would run IBT 20 times as opposed to 1 to test for stabilty. I would expect it to crash as 1.15v seems way too low. Most of them need at least 1.25+ volts. Mine needs about 1.2650 vcore for reference.
hey, just woke up. left prime running all night, around 8 hours+ and it was stable but I did raise the voltage @ 1.15 as opposed to the pic that is at 1.12
Sounds like you have a good chip there M1K3H :D
Keep going I reckon.
Try prime95 small fft's to really stress the cpu
But unless you are running 24/7 100% cpu I wouldn't worry too much.
it was the small fft's that i ran before.. max temp was 85, think i'll stick to 3.8 bcos to 4ghz the increase in voltage and temp would be more than i am happy with. that is untill i care to settle those nasty cables down there and free some airflow;p
