Re-setting overclocking
3 Jan 2005
PC is "Ultima OC 280 GTX" Intel Core 2 Quad Q6600
I bought this ...runs really nice..but i had a problem...can you help me?
My daughter fried my G15 keyboard so i had to use a cheap board for a temp solution..but this has stupid keys above the scroll lock ..they are ''sleep, shutdown and standbye'' of course with lit keys gameing is great..but if u play and hit one of those..it shuts down..and doesnt restart..
My problem is the overclocking was said to reset..and i was wondering what the actual settings are..so I can check it is still correct.
Thanks in advance
you can e-mail them or post here...thanks
Is that this system?
If so then 3ghz should be prety simple to get again. It really should just be a case of upping the FSB to get 3ghz (set the FSB Frequency to 334mhz) and making sure that the DRAM Frequency doesn't exceed DDR2-820 speeds. You'll also need to set the DRAM voltage to 2.1v.
Other than that you shouldn't need to touch any other voltages for 3ghz.
