Re-using current Ram for Ryzen 3900x possible?
23 Sep 2012
South Yorkshire, UK
I need a bit of advice on RAM, my current system is using this: Corsair Vengeance LPX 32GB kit and i'm slowly collecting the parts for a Ryzen build, got the cpu, got the cooler, just need the case and Mobo (either a Gigabyte x570-I or Asus x570-I), i'm going to reuse the psu and gpu, i want to reuse the RAM as well if i can, would the current kit i'm using be good enough?
Or should I get a new kit? What speeds are optimal for stability with a 3900X? I'm aiming for 32 GB capacity.
Hm, so i'd be able to reuse my ram just fine? I'd just have to OC it? It's rated for 2666MHz, and i was told in another thread that is a bit slow for Ryzen.
Well my main monitor is 1080p, i do have a QHD 27 inch Wacom Cintiq (goes up to 2560x1440 i think), only use that for zbrush though. As for my gpu, it's an RTX 2070 Super.
Sorry, I misread, my RAM is the exact same, but my frequency is 3200mhz, and enabled XMP in the BIOS.
Ryzen prefers faster RAM, so could be a consideration for more..
Personally it wouldn't bother me, especially as you have 32GB (like if it was only 8GB then it'd be upgrade both ways). I don't know anything about zbrush, so couldn't say what impact it would have there.
