Re-using incompatible for DC twinmos
15 Jan 2007
just a heads up - if your unlucky enough to have some sticks of old, doesnt work on any dual channel device twinmos you can still use it - and get dual channel!
the only requirement is you must have another set of ram that will work DC.
match the ram up for the first stick in each paired channel is from the good set, and the 2nd stick is twinmos carp, so on a board ith slot layout 1234 being C1 C1 C2 C2 you would have ramset as good bad good bad, if your ram went 1234 C1C2C1C2 you would run good good bad bad.
