- 9 Oct 2013
- United Kingdom
Hey Guys,
So I am upgrading my rig this week from my original build:
Case: Corsair Obsidian 650D
MoBo: Asus Rampage IV Extreme
CPU: i7-3930k @ 4.8Ghz
GPU: Dual Asus GeForce GTX 680 in SLI
PSU: Corsair AX1200i PSU
RAM: Kingston HyperX Beast 16GB
Cooling: Corsair Hydro H100i & 4 x Corsair AF120
SSD: OCZ Vertex 4 256GB
HD: 4 x Western Digital Caviar Black 2TB in Raid 10
Screens: 2 x Dell Studio S2340L 23"
to this build:
Case: Corsair Obsidian 900D
GPU: Watercooled GTX 780 Ti
Cooling: XSPC AX480 Quad Fan Radiator, XSPC D5 Pump + XSPC Top, EK-RES X3 250 Res, XSPC Raystorm CPU Waterblock, 8 x Corsair SP120, 8 x Corsair AF120, XSPC fittings (3 x 45 deg, 1 x 90 deg and 10 x comp), and Mayhems Pastel Red Coolant
SSD: 4 x Plextor 512gb (Raid 10)
HDD: 4 x Western Digital Caviar Black 2TB (Raid 10)
Screens: 3 x Dell Studio S2340L 23"
What I want to do with this new build is include some sort of water-cooling maintenance system. I've had a little idea, and want some feedback/suggestions on it... So, here it is:
Using two pairs of quick disconnect fittings, one placed after the pump (which is after the res) and the other one (separated in to male and female) attached to two spare bits of pipe. When I want to clean and flush the system, I disconnect the quick disconnect after the pump, then connect the spare pipes to both the pipe coming from the pump (and placing it in a bucket/bowl) as well as connecting the second spare pipe to the other end within the system (to allow air to travel through to purge the system). I then use a PSU bridging connector to turn on the pump, pushing fluid out of the system.
My first question is will this work, and the second is is there a better alternative?
Any suggestions/help will be appreciated! Cheers
to this build:
