- 8 Feb 2012
- London
Hello.
I have created my raspi to be read only through several guides, which works perfectly fine.
However I'm having a problem to write logs into certain files. I tried logging data into the /var/log file but it doesn't seem to work unless I use the remount function.
These ones make the most sense to me.
http://raspberrypi.stackexchange.com/questions/5112/running-on-read-only-sd-card
http://blog.pi3g.com/2014/04/make-raspbian-system-read-only/
Does anyone know, if I can edit the fstab file to give me the option to write in the /var file? Also it doesn't have to just be in that file, it can be in any as long as writes.
Thank you.
Thank you.
