Reading Done - Time for Doing
5 Aug 2004
North East England
Over the past week or so i've been reading about overclocking and what to do and how to do things. So i've finally plucked up the courage to go a bit higher than an extra 20mhz on 200 :D My current rig is as follows:
AMD 64 3200+ Newcastle
GeIL 2x1GB PC3200 Value Dual Channel Kit CAS3
Asus K8N4-E Mobo ( Socket 754 )
GeForce 6800GS
3dAurora Chassis with two 80mm in-take and outtake fans.
Scythe Ninja Plus Rev.B Heatpipe CPU Cooler
So i've been messing about for a while now with bios etc and managed to get from 2.2ghz to 2.42ghz(220x11) nice and stable. But now i've managed to get to 2.53ghz(230x11). I know i've done some settings wrong somewhere and that some things are wrong but I just can't see where. Here is what it currently looks like:
So how close am I to blowing my computer? :)
To me the HT Link is too low, maybe i've read something wrong and maybe it's fine, and I think my RAM settings are wrong. I just changed them until XP booted :rolleyes:
Going to see how long SP2004 lasts for.
Wingz said:
whats your temps like? for me command rate should always be 1T for performance.
Just ran SP2004 on 'Small FFTs' for 4minuts and 39seconds and my CPU got to the highest of 54c, barely though, and got this log:
Me said:
Type: Small FFTs - stress CPU Min: 8 Max: 32 InPlace: Yes Mem: 8 Time: 15
CPU: 2530MHz FSB: 230MHz [230MHz x 11.0 est.]
02/01/2007 20:48 Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
Test 2, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
FATAL ERROR: Rounding was 0.4995117188, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 4 minutes 39 seconds - 1 errors, 0 warnings.
Execution halted.
Will edit the post after Large FFTs and then Blend.
Edit 1: Large in-place FFTs ran for 1minute and 22second and got around 50C
Me said:
Type: Large, in-place FFTs - stress some RAM Min: 128 Max: 1024 InPlace: Yes Mem: 8 Time: 15
02/01/2007 20:55 Beginning a continuous self-test to check your computer.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Torture Test ran 1 minutes 23 seconds - 1 errors, 0 warnings.
Execution halted.
Edit 2: Blend ran for 2min 4seconds and got a max of 54C
Execution halted.
If it fails like it has the CPU is unstable. You'll need to increase the voltage or go for a smaller overclock to achieve stability. I wouldn't expect a great deal more from it as the newcastles aren't great clockers but I'd expect you should be able to get 2.4/2.5 stable from it.
El Jimben said:
Not that it makes a huge amount of difference (if any) but your HTT/LDT multiplier should stay at 4 until you get to 250 FSB, then reduce it to 3 to stop the overall speed HTT speed being greater than 1000MHz. Also, can you post a screenie of the 'SPD' tab from CPUZ?
My computer wouldn't boot if my my HTT was on 4 anywhere after 220 unless it was on 3. Will edit with SPD tab, one sec' :)
Edit:
Yep, and see what happens if you set the command rate to '1T'. It won't necessarily increase your overclock but it will boost performance a little.
El Jimben said:
Ignore me, the HTT should be 1600MHz (800 x2) for 754 chips I think :o
Yep, that's right.
All looks good to me - need to drop the CPU speed slowly until it becomes stable. It lasted nearly 5mins on Prime so I reckon it might be stable at 2500ish.
Something isn't stable in your system. First thing to do is to set your RAM to it's stock settings and using a memory divider keep it under it default speed (you can test with Memtest to make sure the RAM is working right as well). If all is well then either your CPU needs more volts, or it too hot, or you chipset is the same.
Jokester
Jokester said:
Drop your HT multi to x3 as well.
Jokester
Yeah I have, took me about 2hours to work that one out. Almost turned emo as I couldn't get it to work :rolleyes:
set your ram timings to 3-4-4-8 just incasae thats whats limiting you
Done that and seeing what happens. :)
Edit : Command rate is now on 1t and all is fine.
Hmm, I raised the VCore to 1.575 and my comp failed to load and so I reset the bios using the jumper. I instantly went into bios and overclocked once again back to everything above but like 1.55 again, i'm running SP2004 and i'm maxing out at 45C?! The only difference is my case side is off :confused:
SP2004 has been running Small FFTs for 7minutes now perfectly and still only 45C, i'm very confused? Surely the case side cannot make this much difference.
Jokester said:
That's normally a sign that air flow through your case is pretty bad.
Jokester
I'll take some photos, give me a minute.
Edit: Ok, sorry for the quality but it's from my phone.
There is the intake fan which blows air across my HDs and into my fan.(The blue thing on the front :p )
And here is my cooler, which also has a fan attached to the bottom which blows air up through the CPU and on the left are the two fans which pull air out of the computer.
Jokester said:
Nah, no need for photos, what case fans have you got?
Jokester
Too late :p
Edit: SP2004 been running for 16 minutes 48 seconds on Small FFTs @ 2530MHz (2530-2531) and still only 45C
