Reading engine management light codes
17 Jun 2012
Can you do this yourself, I see you can buy scanners etc for around £20, are they as good as what a mechanic would use. Is it as straightforward as getting the code then looking it up?
From what I can make out it may not be that simple?
I wouldn't be without one, but a generic code reader is only semi useful. Sadly they often will simply throw fairly generic fault codes which are no use on more complicated cars. Mercedes for example you will be lucky to really get much from a regular reader.
So what one do you have and why would you clear codes, surely you need to fix the problem first?
