Ready built pc
17 Apr 2007
Just need some info about the ready built pc's, gaming config pc that OC build, if I was to buy one of those am I allowed to put more hard drives in the system, or would that void warranty?
If you plan on changing the configuration of your pc in the future I would recommend one of the following:
Quickly learning how to build one so that you understand how things work together, and build it yourself. This will make future upgrades less hassle/stress
Get a techie in to do it for you after you get a pre-built system
from what I believe the warranty for pc components are on individual parts so modifying the computer shouldn't affect the individual warranty of each part (ignoring damage to each component as a result of user error)
