Ready to click order, would really appreciate a few reviews before I pay.
28 Sep 2012
So I'll be using this build for gaming mostly. I won't be doing much else on it, maybe a little streaming at times.
I'd really appreciate it if someone could look through this build to tell me if all the parts are compatible and if the PSU is big enough to support the system.
YOUR BASKET
1 x Sapphire Radeon R9 290 Tri-X 4096MB GDDR5 PCI-Express Graphics Card (11227-03-40G) £329.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £167.99
1 x Kingston HyperX Fury White 16GB (2x8GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (HX318C10FWK2/16) £109.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £87.95
1 x NZXT Phantom 410 Enthusiast Midi Tower Case - Black/White £84.95
1 x NZXT Hale Power 90+ 550W '80 Plus Gold' Power Supply £49.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £43.99
1 x Arctic Cooling Freezer Xtreme Rev.2 High Performance Quiet CPU Cooler £29.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £944.75 (includes shipping : £19.10).
Looks like you put some thought into the colour scheme yet while the Tri-X cooler on that GFX card is amazing, its orange and doesnt really fit in
Ha, yes I noticed that just as I went to place the order, which sent me over budget so I couldn't actually afford my order. Luckily a few things went slightly down too, so I changed my order a little and went with this.
Kingston HyperX Fury White 16GB (2x8GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (HX318C10FWK2/16) £91.66 1 £91.66
NZXT Phantom 410 Enthusiast Midi Tower Case - Black/White £70.79 1 £70.79
Gigabyte Z87M-D3H Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £69.16 1 £69.16
NZXT Hale Power 90+ 650W '80 Plus Gold' Modular Power Supply £54.99
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD
DPD Next Day Parcel (Mon-Fri): £12.50
VAT: £156.65
Order Total: £939.88
This will leave me with just over £60 left of my £1000 budget so I can pay OC to build it for me. Budgeting within 12p of my limit =D.
Where is the ssd? I woulve replaced that case with a bitfenix ronin which imo is better and cheaper, gone with an ssd and watched youtubes videos on how to put a pc together, i too had doubts and fear of doing it myself but its really easy and addictive lol, like lego for kids
Yes I dont get it how people can buy parts and then pay someone to build it, Its fun and don't require that much skills to do it ur self, u can be proud of ur achievement as well
I've just have a bit of a crush on the Phantom ever since I saw it, if I'd have noticed the Ronin I'd have probably looked into it as it looks pretty sweet too. I'm a little scared building computers ever since I bent the pins on my CPU trying to change the heat sink =/.
Someone used it in a build recommended to me on the forums so I thought I'd go with it. Is there something wrong with that type of board?
No problems its just normally you for the board to your case (upto ATX). As there was no reason for you not to have an atx board its seems an odd choice.
On the other hand you now gave the option to get a 350D. :)
