Real difference between 2 mobile CPU s
Caporegime
8 Sep 2005
Norrbotten, Sweden.
Intel Core i7-6500U 2.5GHz
Intel Core i5-6200U 2.3GHz
It's 70 quid more but both are still dual cores 4 threads?
Well, we all pretty much know that Intel mostly uses the same die for the mobile lines and that i3/i5/i7 mean little:
i3 is 2C/4T with no turbo,
i5 is 2C/4T with turbo,
i7 is 2C/4T with more turbo and a larger cache.
(There are mobile i7's with 4C/8T but those are 35W/45W etc. and to confuse things further, Intel now have mobile i5's with 4C/4T.)
As well as what DragonQ has said, the i7 gets a higher turbo so for stuff not utilising all the cores it should have better race-to-idle.
Here are the arks:
i7-6500U http://ark.intel.com/products/88194
i5-6200U http://ark.intel.com/products/88193
i5: Turbo up to 2.8GHz
i7: Turbo up to 3.1GHz
Which is inline with their base frequency.
That i5 also doesn't support Intel vPro but that's probably only relevant in business laptops.
In terms of performance it's about the same as a desktop celeron processer according to the benchmarks I've run.
