- 29 Jan 2007
From what I've been reading, people get themselves in a right twist over DTS/core sensor readings from CPU's. It got even worse when 45nm core2's were released as some of these sensors varied or were stuck at low temps. People were sending back CPU's over differences in DTS sensors and these programs are to blame for not making things clear.
From what I can tell, DTS sensors are only used to trigger throttling and shutdown for each individual core. They are not calibrated to give any kind of accurate reading across temp ranges, so their values are of no importance. They are factory calibrated individually per core to throttle at a point before damage or errors creep in. Not every core is calibrated exactly the same or gives out the same readings, but each core will throttle and shutdown correctly so no point analysing these sensors.
The only temp reading that matters and the one Intel base all their requirements and max limits on is the Tcase sensor - and that should always be below say 70C (for some core2's, depends on CPU type) under load. Usually this is the one the motherboard reads.
No matter what the DTS sensors are reporting, keep Tcase under the specified value set by intel and your CPU will work fine. The CPU will hit Tcase max way before any DTS sensor triggers throttling regardless of what reading they are churning out. So why all the obsession with core/DTS readings?
