Realbench crash with cuda enabled on 980ti
8 Nov 2006
I'm still investigating, but I was getting a lot of crashes trying to stability test new cpu and board.
I assumed it was cpu/mem/mobo combo, but for some reason I disabled cuda in nvidia control panel, and while I'm still making sure, I don't seem to be getting the crashes thus far with it disabled.
For clarity, I had it enabled, crashed. Turned it off, passed. Currently testing with it off again.
Anyone else able to try this? Or heard of it and know solution? Latest nvidia drivers, no overclock and water-cooled.
I've experienced it in the past. Are you running the stress test? If so, try running the benchmarks instead.
Just a total lock up. No output to screen. Does not power down or reset. No bsod.
Can't see anything specific in event viewer.
I don't have another gpu, and have stressed this one before in realbench.
I have had the same issues with other memory on same board.
Everything pointing to this board. Plenty having issues with Asus Am4 boards. I just got sidetracked (and hopeful) it was something else.
Thanks for your time though.
