really annoying temps..
11 Dec 2005
the mighty hereford
just fitted a arctic freezer 64 pro today as a stop gap for w/c now i have a lian-li pc7+ with all case fans and when i boot up and idle its at 23/24 oc. then its like this for 30mins then for some reason it randomly shoots up within like 30seconds. so its really annoying me. what could be the problem. i am using speedfan?
shoots up to 30/31 degrees when i know it cant be. the chip i am using is a amd thlon 64 3800x2 clocked to 2.5ghz. it never used to do this on stock cooler,that kept it at 30degrees idle. so i know its not because of the overlcock.
i dont think there is a problem with speed fan to put ** mind at rest u could uninstall it then re download it ?
all computer increase just after they have been booted up especial if it in a cold room i wudnt worrie about it mate them temps look fine the frezzer 64 pro is a very good cooler ive got one mine idels at 27c but boots up at 23c at the moment these temps do increase in the summer hope this help uve got nothing to worry about
