Really Annoying!
20 Oct 2002
North West
Example:
I extract a 30gb file from drive D to drive F (different drives) and it gets to about 30% and then starts to leak memory everywhere!
It always does this with big files. Similar to when Kaspersky got to 96% then my RAM usage went sky high.
The problem? Nothing seems to be consuming more memory than it should :confused:
It's highly annoying. It gets so bad that my mouse will jerk/bring my PC to a stand still. It's as though my PC is starved of bandwidth :(
How are you extracting the file? I am assuming it's a zip file or something.
You could try using a different app to unzip/extract the file, maybe something like 7-zip.
