Really bad "jaggies" in HL2. Please Help!
12 Sep 2003
Newcastle, UK
Hi all,
I've noticed since re-installing HL2 to play again with my GTS that the image is quite shocking! :confused: Please see the two screenshots below (I linked to full size 1280x1024 so as not to compress the problem):-
1. Notice the top of the water tower and the sides of the large tower.
http://img.photobucket.com/albums/v223/j_firegod/Computer/AA_2.jpg
2. The top of the window frame.
http://img.photobucket.com/albums/v223/j_firegod/Computer/AA_1.jpg
These are just two instances of the occurance around the game on most edges. So I checked all my settings which are as follows:-
In-Game
All maxed out (1280x1024), with AF forced to x16 and AA forced to the most - x6 AA
Nvidia CP
All maxed out, with everything set to High Quality (No Optimisations) and AA forced to x16 (Enhance Application) and AF to x16. Vsync on.
I'm really annoyed, because I don't remeber them being that noticeable. Do I perhaps need to disable AA "in-game", although then the Nvidia Enhance option wouldn't work, would it?
Thanks for any help! :(
yeh hl2 is exceedingly ugly with 6xaa for me. I'm sure it's even more ugly than when I set no aa, but I think that's just my imagination
eh, i can get 6xaa without a problem on this 7600GT. :confused: Also, i had exactly the same problem where AA wasn't "activating". Basically, i checked that i'd set AA to auto in NVControl Panel, and restarted and changed setting for AA from 6x to off and then back again. Seemed to do the trick.
Well that's done the trick peeps! What would I do without you all! :p
Can't believe it, I just assume "ok x6 is better than x4". Never thought that it wouldn't work. I've set it to x4 and now it looks amazing. No jaggies at all!
Two screenshots to compare against the above ones if anyone is interested:-
:cool:
