Got my G0 today, and no matter what i do it will not go over 2.69GHz (299x9 / 1199 FSB) If i increase the FSB by 1MHz more, to 1200MHz, it will not boot windows Vista or XP. Sometimes the system posts ok, but as it goes to load windows it restarts.
I've tried:
Loads of diff FSB speeds from 1200 - 1610MHz. None of them will work, anything under 1200MHz works though.
CPU voltages all the way up to 1.5v
Increasing chipset voltages, RAM and FSB voltages.
Lowering RAM speed to just 650MHz with 5-5-5 timings.
Disabling C1E.
Lowering multiplier to 8x or 7x.
Nothing works!
is there anything else i can try?
BUT i think it's my board, as it's a EVGA 680i SLI mobo, and i got it not too long after it came out, now i remember back then some 680i boards had crap capacitors or something so you could not go over 300x9 with Quads, but they fixed it later with newer board revisions. I'm guessing my board is one of these?? If it is, do ALL new 680i mobo's now have this problem fixed? 'cause i'll get a newer EVGA one if they have.
I've tried:
Disabling C1E.
Nothing works!
