- 13 May 2015
Components Needed and have a budget of £250 not including the GPU. I have listed the components that i was thinking about so take a look and advise what would be bang for buck the best overall for performance.
So the 5 components listed what overall on this site what are the best for gaming performance.
CPU - Intel Pentium G3258 CPU (Dual Core 3.20GHz, Socket H3 LGA-1150) £60
Motherboard - MSI Z97 PC Mate Intel LGA1150 Z97 ATX - £65 (Will need a good board for a bit of overclocking and also to install an i5 cpu down the line)
or
Asus H81M-PLUS Intel H81 £42
Ram - Budget £40+
Case - Budget £20+
PSU - Budget £40+
Will be getting in the next few weeks
GPU -
SSD 120 Gig
Monitor
Will Be needing A GPU in the next few weeks so is it worth getting 1 AMD card now so in the furture i can use crossfire or settle for 1 good card For around £100
or
Ram - Budget £40+
Case - Budget £20+
PSU - Budget £40+
GPU -
SSD 120 Gig
Monitor
