- 18 Mar 2008
I think that it's 3 pin
Tbh I don't know, but if you want to run multiple fans off a single header I'm assuming you'll need more juice per header than this FC to offer. My Rheobus for example is 20w per channel.
Thanks for making me aware of the issues you have had with the controller mate its made me think twice about it.
That'll be it, someone had a dead battery with theirs out the box. Pay a few more pennys for a silver oxide one and it'll last much longer than an alkaline, it'll hold up better to extreme temperature swings aswell which is probably what helped kill the cheap bundled alkaline one.i know others have had issues with the battery life being pap, but that could just be rubbish batteries provided with it (i'm yet to change mine out as i really cba with it anymore)
cheers twist i have red a lot of reviews on it and one of the things that a lot of people pick up on is the screen is only "readable" when you look straight at it so to speak. Any slight angle and it becomes abit "obscure". I just really liked the look of it but if im paying nearly £50 for a component i want it to do its job if you see what i mean.
I was thinking of getting some yate loons fans for my case heard good things about them, what do you think of them mate? cant seem to find them on the OCUK site tho.
Centurion- I dont think the molex plugs are detachable from what i can remember but i will have a look.
Thanks again everyone for your help really appreciate it
If you've got a volt meter you can get a rough indication of the state of charge. The voltage should be about 3.6v out the box, sit at around 3.3v for the majority of it's life and be near enough dead once it's below 3v.
they move a good amount of air 47CFM with a noise DB of 25. The yate loons are about the same a little bit quiter at 23DB. The best fans i have come across are the Akasa Apache fans the give an airflow of 57CFM and a wopping noise DB of only 16 which is fab! Currently got 2 of these of my cpu coolerdo 'standard' fans even use 4w?
, however if you did, you will most likely exceed that 4W.Just had a look at the NZXT fan range and they look really neat and classythey move a good amount of air 47CFM with a noise DB of 25. The yate loons are about the same a little bit quiter at 23DB. The best fans i have come across are the Akasa Apache fans the give an airflow of 57CFM and a wopping noise DB of only 16 which is fab! Currently got 2 of these of my cpu cooler
4W per channel really is nothing if you want to run a 2000rpm fan full whack, search the manufacturers site for specifications of the fans you want and they usually tell you current usage at different rpm.
Easy to work out from there, although I doubt you would want to run any 2000rpm fan at max unless you are deaf, however if you did, you will most likely exceed that 4W.
