- 23 Jul 2012
- Mirfield, West Yorkshire,
Hello all,
When I play Minecraft it stutters like hell and reports 60-70fps although I know its dropping suddenly then going back up to 60-70. It used to play fine with 300+ fps, and yes I know my monitor cannot display that, nor can I see that, but thats not the point. It now runs like crap.
I have also noticed a drop on Battlefield 3, used to be able to run 90+fps on Ultra, now down to 45-55fps. Cards reporting 65-70%
In Minecraft my first card does not go past 20% usage, and obviously the second is not used due to Minecraft being OpenGL based and not SLI supported.
My spec is as follows;
CPU: AMD FX-8350 Piledriver (4.0Ghz but clocked at 4.4Ghz with no difference to result)
MoBo: Asrock Fatal1ty 990fx
GPU: GTX 560ti 2Gb's in SLI (One is an ASUS Card, the other a POV, both with matched clocks)
RAM: Patriot Viper 8Gb 1600Mhz (XMP Profile, 2x4GB)
PSU: Xigmatech Centuro 800w
CPU Cooler: Corsair H80 P/P
HDD: Seagate Barracuda 1Tb for OS + Programs. Other mixed HDD's for other purposes.
Latest BETA Drivers, though I have tested previous drivers.
Temps;
CPU: 59'c on Prime95 for 4 hours @4.4Ghz
GPU: 80'c + 82'c on Furmark 4 hours
Any ideas?
Temps;
Any ideas?
