So! After installing my Monoblock, I checked online instructions to double check where my thermal pads should go. Noticing I put one in the wrong place, I'v taken my monoblock off.
This is where the problem starts, The monoblock come off fine all except one stand off which come out of the monoblock :\ pic: http://imgur.com/a/Dt8WX
Any suggestions on how to get it off...... It feels like the screw hasn't gone in straight, I'v tried using pliers, used some rubber tubing with cuts to add friction but it wont grip, the standoff is circular.
Drilling isn't an option, I don't want to have to RMA the block either if it can be helped. The thread that goes into the block looks fine. Help please
EDIT: Pic link added
