right people,as some of you may know im looking for some 25mm spacing radiators (need 2 more).
ive been using my google skill's and have come up with a idea that someone posted a while back.
he said "why dont you just use the 4 corner screw holes to hold the rad onto the case",now this seem's like a really good idea and will work on my case perfectly.
now,the other problem this leads to is the length between the 2 screws(left to right spacing),on my case it is 14 and a half inches between the far left and far right screw hole's,if i could find a rad that will have those dimensions then i can carry on.
at this point in time im thinking of chucking it all in and going back to a smaller case due to this problem.
so watercooling people of uk,have you got the time to measure this dimension's for me please or come up with some idea as to how im going to fit 2 rads in my case.
