Hi guys
Please help,
I have just bought a pair of Devolo home plugs that is internet through the power lines, it works but the box says it can stream HD content like 1080p HD movies to another room. The thing is it does just that on my second floor if i am on the side of the house near my router downstairs, but when i moved to the other side of the house or to my top floor it can't stream any kind of HD. It's a real shame as i had been waiting for this tech to come out for like 2 years now and i had even discussed it on these boards with people.
I am looking to go for the total solution of having my house wired with an ethernet cable, To get a good signal on my top floor to stream HD 1080p movies what is the maximum length of cable you generally go for?
I don't know if this is true but my mate says that if you want to rip your blueray and HD-DVD movies to a PC and then stream them to another PC then on a ethernet cable it would not be able to play because he says that HD-DVD has a video bit rate off 30 mbps and blueray has a bit rate of 40 mbps, But on all routers nowadays you get 4 T10/100 lan ports so standard cat 5 ethernet gives you 100 mbps and then there is cat 5 e ethernet which gives you gbps (giga bits per second)
But my mate says that there is no point getting cat 5 e ethernet as no router on the market yet has gbps ports, but he says you can still buy them and use them but you just won't get the gbps speeds, it will revert to standard 100 mbps speeds. But i have noticed in cost wise there is not much difference, just like £10 difference from 100 mbps to gbps.
no talk of ripping or warez please
If i was to do the wiring it will probably be better to drill a hole and make the cabling from out side my house and in through the roof that way i can hide the cables behind drain pipes, as if i wanted to do it from within my house i will have cables everywhere, also is it better to buy multiple lengths of cable and have them connected up through a switch or adapter or just have one length of cable, i see you can get 60 meter even 100 meter cables and they don't cost very much, i don't know about the waterproof ones, if you know any links where i can get them, then pelase share?
But will a HD 1080p stream be able to be carried over 60 to 100 metre cable? i ask this because my mate said it may not and that's why it's better to use 2 or 3 shorter cables and link them up with a adapter?
I really hope you guys could help me out with my questions.
Much appreciated
TIA
Please help,
Much appreciated
TIA
)for loose screws on the terminals
