Really Need Some Help with Spec!
7 Nov 2006
Stockton on Tees
Hi There
Really need some help with specing up a media centre PC for my bedroom.
Not looking for anything flashy or fast. Just something that is quiet and can cope with playing tv and movies.
Budget is £300 - £400
Will be looking to networking it with the main pc via wireless.
PS. What connection would i need to plug it into a tv?
Something like this:
Microsoft Windows Vista Home Premium 64-Bit Edition DVD - OEM - 1Pk (66I-00788)
£59.99
(£70.49)
Intel Core 2 Duo E4300 "LGA775 Allendale" 1.80GHz (800FSB) - Retail
£68.99
(£81.06)
Optiarc NEC AD5170 18x18 DVD±RW Dual Layer ReWriter (Silver) - OEM
£16.99
(£19.96)
Maxtor Diamondmax 21 320GB STM3320820AS SATA-II 8MB Cache - OEM
£36.99
(£43.46)
Antec NSK2400 Desktop Case - 380W SmartPower PSU
£51.99
(£61.09)
Linksys WMP54G Wireless-G PCI Adapter
£14.99
(£17.61)
Hauppauge WinTV HVR-1100 Freeview TV Tuner
£32.99
(£38.76)
OcUK 1GB (2x512MB) PC2-6400C5 800MHz DDR2 Dual Channel Kit
£17.99
(£21.14)
Abit IP-95 Micro ATX (Socket 775) PCI-Express DDR2 Motherboard
£31.99
(£37.59)
Sub Total : £332.91
Shipping : £10.95
VAT : £60.18
Total : £404.04
You may want to check if that TV card is MCE compatible though. What TV do you have? Does it have a DVI or D-Sub connections?
That depends on what connections the TV has ...
If it's an old one then it will probably only have SCART/S-Video in, in which case you'll need a graphics card with S-Video out; if it's a new one then it'll probably have VGA/DVI in, in which case you'll need a graphics card with VGA/DVI out. You really need to say what inputs your TV has though :D
Edit: beaten
I havent decided on a TV yet folks. It will certainly be something like a 32" samsung (like OC stock)
Also, does the freeview card need to use an external aerial (like TV's which havent gone digital? TV aerial on roof)
Even digital TVs need to use an external aerial (unless you use cable or some crazy new-fangled internet thing ...) and yes, the freeview card needs to use the aerial too. They'll possibly give you a crappy little aerial with it but that will not work very well ...
If you get the Samsung then the previous spec is fine - just plug the TV in as you would plug the monitor in to the onboard VGA.
