Really, really flexible GPU riser cables.
20 Apr 2015
Hi
Are there any really flexible GPU riser cables that you can fold flat ( and put creases in them with a steam iron) like you could with the old IDE cables. I'd like to route the riser down from the PCI-E slot, then fold it at 90 degrees rearwards, then fold it back on itself so it's going forward towards the front of the case, then turn right or outward to attach to the GPU.
I really don't know if any of that made sense!
Thanks
d
Get one custom made from some of the cable guys on here? Might cost you a few quid but will be bespoke to you and your situation
