Really slow USB3
28 Aug 2012
Durham
I have an Antec 302 case with 2 USB3 ports on the front panel and a Gigabyte GA-Z77-D3H motherboard. At first, both front ports were fine, then one day the right one went really slow and hasn't got better, I've tried making sure it's plugged into the motherboard properly, I've used different BIOS versions, I'm on my second install of windows 7 and there's no visible damaged pins inside the port, it's not just USB3 devices either, USB2 are really slow as well.
Then just the other day the left port has done the same, so now both are really slow, the rear USB3 ports are all fine, but not as easily accessible for memory sticks!
Is this likely to be a motherboard or case problem? I'm thinking probably case because the rear ports are fine (so far!), what are Antec like to deal with? Am I likely to have to return the entire case?
It might just be an issue with the Antec USB ports. I have the P280 and one of my USB2.0 ports does`nt seem to work and has been that way since I bought it. You could check the wiring coming from the ports and make sure they are properly connected.
But also as RJC has said, check your controllers are up to date.
