Hi All,
I have searched for tons of videos and reviews, and unfortunately almost all are gaming orientated. I am not a gamer and so a lot of the information just isn't relevant.
Current Setup and use
2x Standard 27" Benq monitors
WFH in Digital Forensics and Cybersecurity
A lot of looking at data, spreadsheets, some code, report writing, outlook, Teams calls etc.
Options
I have ruled out a 49" as it just seems too wide and just not a good fit for me personally
34" looks reasonable although I keep wondering if the £400-£500 would feel worthwhile based on the size gain
38" looks brilliant however the cost is really high, about the £1000 mark I think. Although I could in theory afford this, I don't think I could justify that high a cost
I would retain one of my 27" monitors, most likely turning it into a portrait orientation to the side
I have read that a 4k monitor for my kind of work would be a good move
My questions therefore are:
Thank you
Lorna
Options
- Have you looked or considered these two sizes before and if so, what were your conclusions?
- In relation to my use (data/work - no gaming), any particular thoughts on what would be best?
- Any recommendations on brands or particular models?
- Finally, anything else I should look out for? Although I am very technical in knowledge, I completely glaze over when looking at monitor specs and things like refresh rates, panel types, resolutions, etc. I therefore struggle to understand what it really means for me and what is/isn't important.
Thank you
Lorna
