Yesterday I built my new gaming rig. I have built PCs before so I know my way around it.
The only items being reused from my old rig were the PSU, Graphics card GTX280, a Creative Sound card, and 4 Hard drives - 1 SSD and 3 HDD oh and the DVD writer.
The PC boots up fine and lights up I can get into bios everything seems fine and dandy. I then go to install windows 7 on my SSD. It takes a while but it installs ok and I get windows boot up. I install firefox and update the important updates I then reboot. After the reboot the system all seems to go to hell. It reboots back up with the DPS (Diagnosic Policy Service) not working so I cannot connect back to the internet. I had a look on the internet and couldnt really find any solution to fix it other than system restore.
I then do a system restore from when it was first installed, so before any updates or firefox was installed. The system then reboots upon boot up it just goes straight to the System recovery menu and tells me it cannot fix the error. It now wont let me even get to windows
So I decide to start again and re-install windows. I do the same process but it happens every time. I have re-installed windows 7 now like 6 times and the same error. It boots up once then as soon as I restart the system, even if I dont install or do anything as soon as I restart the DPS goes and everything kinda goes to hell after that.
I really have ran out of ideas. I know the SSD is working as it was running windows 7 fine on my last rig.
Any help would be greatly GREATLY appriciated.
Thanks
Thanks
