Really wierd speaker issue
9 Jul 2017
I have a pair of Bose Music Monitor speakers and im having the wierdest issue with them, when testing in windows i only get noise out of the speakers when it tests the right one however i get sound out of both speakers then in mono. Obviously ive set them up as stereo and tried with a pair of headphones which tested fine. Ive also tried a USB sound card and im having the same issue with the speakers. If the left speaker simply didnt work obviously it would be at fault but how the hell can I get mono out of both speakers ??
Have you tried different cable?
And if same problem exists with different signal sources cause is likely in speakers.
So try to test with other computer or any kind player with line out.
If that's the case then it would be time to start checking insides.
