Realtek drivers :/
LAN(s) enabled in BIOS?
not an OS problem (firewall etc.)?
tried another set of drivers from Realtek's site?
My laptops LAN port refused to work when I first got it this is how I fixed it. If the LAN port is working try going into control panel / network connections right click on your Local area connection click on configure then on the advanced tab and select speed /duplex settings, it is probably set to Full auto negotiation, try setting it to Force full duplex or one of the many others.
Hope this helps
Same happened to me on win7 after a windows update, I just went to device manager and done a rollback then it worked fine for me!
