RealTemp 3.0
Bit better, thanks for the heads up sithlord! :D
I have been using Real Temp 2.1 for a while, does anyone know the reason why there is so much temperature difference from the two versions?
Real temp 2.1: 37c 30c 39c 28c
Real temp 3.0: 43c 44c 34c 36c
i believe intel released details on the tjmax values of most of their current lineup. The old version used 95c, the new version uses 100c. So your temps should be about 5 degrees higher on the new version.
