New version released, much better IMO.
http://www.techpowerup.com/realtemp/
Changes in Version 2.70
* Redesigned user interface (GUI) with larger temperature fonts.
* Added a movable Mini-Mode that is turned on and off with a double left mouse click on the GUI.
* Added an Anchor position so the GUI will move to a fixed screen position after a double right mouse click.
* Anchor position can be customized by holding down the Shift key while double right clicking.
* The correct physical core order of Quad core processors is now reported based on APIC ID.
* Added reporting of Minimum and Maximum VID as well as current VID.
* A new user selectable high temperature alarm with two alarms for Quad core processors.
* More accurate MHz calculation as well as FSB and CPU multiplier reporting.
* New program Up Time feature.
* Bug fix for log file output when using a Single or Dual core processor.
* Fixed and improved the Default button in the Settings window.
* Button labels and functionality changed in Settings window to follow the Windows style guide.
* Improved multi-threading and memory usage for better long term stability.
* Start Minimized option improved for better Vista support. See the documentation for more info.
* Option to save the Log file in .CSV format for easy Excel support.
* Gamer Mode temporarily retired.
