- 18 Oct 2002
- Stockton.
I have been letting my Gigabyte P35-DS4 mainboard do its own thing as far as the so called 'auto overclocking' goes, and it seems to do it pretty well all in all...
I have a Core2 E6550 2.33Ghz cpu with a bus speed of 333/1333 and 7x multi
in its standard form it will bounce between 6 and 7x multi 2000/2333mhz speed
the m/b overclock plays with the bus speed jumping up to 386/1546 indipendant of the multiplier.
these play well on their own, but it would seem the vcore cant be changed on the fly like the speed, this has resulted in an increase in core temps from 38 idle ish to 54. and pushing 70 under load (using a passive cooler btw) load temps where stable around 50 under load before enabling the auto O/c option.
So even when idling at 2ghz the vcore must still be higher....
Anyway, what i would like to be able to do is find something that will log and create a graph for the core speed, bus speed, vcore and cpu temps so i can see how it is performing while in a game.
I have had a look around and havent found anything that works how i would like so far, I am running Windows 7 64bit (which wont make the search any easier sorry... )
thanks for any happy
