reaper settings
6 Mar 2008
wondering if someone could advice what settings i should use, i ordered a preoverclocked system coz im a complete noob when it comes to oc settings
my system was completely screwed and they've sent me replacement memory,
had 4x1g ballistix tracer 8500 and now i have 4x1g reaper hpc 8500, i was told when i got it i'd need to make some adjustments to the settings before i use the new memory, but they haven't got back to me yet so was hoping someone here might know what adjustments i need to make so im not sitting here with an unusable pc all day
the systems a ip35 pro q6600 system clocked at 3.222, i can provide screenshots of all the current bios settings if this would help
hello again :D
well heres both
Well it's only running at 895mhz, so you can stick on the next highest divider/ratio (DRAM Speed 1:1.5) in the uGuru menu. You *may* need to go to 2.3v as that's what the memorys spec says, but i've a feeling the current 2.2v may be enough.
The timings are grand, so no need to play with them :)
And drop your ICHIO 1.5v Voltage down to 1.55v. That's more than enough for your settings.
Good good :)
If you do come across a problem then up your MCH voltage up another setting.
