I've done brakes plenty of times on various cars and motorcycles, but not one with an EPB (Electronic parking brake).
The car is question is a 2013 Volvo S60.
I have an icarsoft vol 2 which in theory....can release the EPB, but not being funny the ******* thing wouldn't even reset the service light so time will tell....
I guess if this works though it's the best way.
Otherwise I've seen some YouTube videos which involve manually winding the EPB back but this involves dissembling the motor for mnthe back of the caliper, and you are supposed to replace the bolts and seals every time you do that, which will be £££££ if you can't easily get those and have to go to Volvo.
I'm also half wondering if I chock up the front wheels properly and try and do it with the EPB released, and disconnect the battery so there is no chance of it automatically engaging half way through, I fear it'll bugger up some sensor doing that though.
Any of you have some general advice or tips?
