Rear drum failed
8 Jan 2005
Macclesfield
Ive had four new tires fitted today at the local garage and all was well, until
I was coming off the local bypass and had to brake quite severely and the car swerved A LOT
After trying again on a quiet road i noticed it was dipping very low at the front and pulling to the left under heavy braking.
After checking all the brakes on the car i noticed the front disks were near enough on fire, one drum warm, and the other cold
Could the tire monkeys of knocked anything whilst fitting the wheels or is it likely to be a coincidence?
Thanks
RM
First of - they're called tyres, not tires.
Take it back to them and ask them to check the brakes over for you.
