on older mini`s the numberplate light was on the carrier plate that you put the number plate on
on the newer mini`s it was on the boot itself
sounds like someone has took the carrier plate off and just put the numberplate straight on to the car
look on here for the old mini http://www.classiccarspecialist.co.uk/9051FN.htm
and on here for the newer way http://www.classiccarspecialist.co.uk/SPT965K.htm
It is compulsory to have a rear number plate lamp. You will have to fit one.
I have a similar situation. 1988 car, fitted with replacement front wings from an earlier car - so it has no side repeaters. I have to cable tie side repeaters to the wing mirrors for the MOT.
