- 25 Nov 2011
- The KOP
Hello I own Pioneer VSX329 with tannoy sfx 5.1 speakers. I noticed other day when testing some audio on PC if I click on say left rear speaker that sound will play out from it but it will also play from right rear speaker, Its the same if I click right speaker sound will play from both rear.
I thought maybe its issue how my PC is setup I have optical cable DTS connect/Dolby Live Sound card and 5.1 selected.
Turns out its nothing to do with PC, on the AVR I can enter the tools options and can play a test tone from all speakers L,C,R SW all play as you would expect then onto rear RL plays and also RR plays at same time, test RR and again RL will also play.
A guy from Richer Sounds said maybe I have it wired wrong for them speakers I have checked and its defo correct.
I have even set the AVR to default settings no luck...
Am completely lost here faulty unit? or something I just simply missing.
Any input here will be greatly helpful. Thanks
