- 13 Jan 2004
- Leicestershire
Hi all,
Bikes CBR 600FX, been sat in garage since last November.
Replaced tyre on rear wheel. However upon refitting it doesn't spin by hand when torqued up. Checked all spacers were in,all 3 bearings span by finger without notchiness. Fitted new cush rubbers but tried with old ones to see if they were an issue - no, no difference.
With nut undone it spins fine - rear brake was dragging a little but freed it off and no issue. Been spinning it without the chain on as thought that might be it but no.
As soon as I tighten axle bolt up it becomes difficult to spin.
Suggestions? Thinking wheel bearings, cush bearing buy they all seem ok.
